Door Panel Questions
Old Jan 11, 2014 | 12:00 PM
PS116:16's Avatar
Car: 89 Camaro RS, 97 Caddy Deville
Engine: 350 TPI, Swap out
Transmission: Automatic 700R4
Axle/Gears: posi trac rear
1. Can anyone tell me how to remove the top cover on the door that is at the window? it is connected to the door panel.
2. Can someone please tell me how to remove the door weather stripping?
I have tried various means of how to remove with no success.
thank you
Old Jan 11, 2014 | 12:52 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Door Panel Questions
1. Turn the threaded washers counter-clock.
To remove the panel from the door
2.
Old Jan 11, 2014 | 12:54 PM
thomas1976's Avatar
Car: 91 Trans am
double post
Old Jan 12, 2014 | 01:14 PM
PS116:16's Avatar
Cool, thank you for the help
Old Jan 12, 2014 | 05:49 PM
mdtoren's Avatar
Car: 1986 Iroc Z28
Just did this today and used these videos..one thing he didnt point out was that the window has to be all the way down and then you can push towards the outside of the door on the panel and lift up and it lifts right out..took me a bit to get that.
Old Jan 12, 2014 | 07:07 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Here is a pic of the inside edge of the door so others can see the clips that hold the top plastic to the door itself. There are lips on the plastic piece that catch the circled area to hold it "locked" down. That's why you are told to pull the bottom of the door panel out about 30*, and push the top towards the window opening to release the plastic lip from the clip edge.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
