Are these bulbs ok for cluster?
Car: 1998 Camaro Z28
Engine: 6.0L
http://www.ebay.com/itm/20X-T10-194-168-W5W-5-SMD-5050-Blue-LED-Car-Wedge-Tail-Side-Light-Lamp-Bulb-12V-/360661876262?pt=Motors_Car_Truck_Parts_Accessories&hash=item53f91f7e26&vxp=mtr
I know ebay bulbs aren't ideal, but being on a budget, I dont mind if i have to pop the cluster out and replace one once in a while. I just want to make sure these are the correct ones for an 88 Camaro cluster and they should be bright enough right? Once cashflow is a bit better I can upgrade to better ones.
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: Are these bulbs ok for cluster?
I bought those and only got 6 good ones. I wouldn't recommend it
Car: camaro
Engine: 3.1
Transmission: auto
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I found that 2 as they only work one way. I had to trim the edge on mine to get them to slide thru the cluster hole. Wasnt hard just took a file to the edge. If you encounter it you will see what I mean
