Window bumpers
Old Feb 2, 2014 | 04:33 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Window bumpers
Under the black trim on the top of the door inside the car are two bass colored bumpers with some felt padding on them.
They have a notch in them that a bolt goes through that allows them to slide and be adjusted.
What is the proper way to adjust these? It seems someone has messed with them in the past and I want to make sure I set them right.
Thanks.
Old Feb 2, 2014 | 10:03 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Window bumpers
Those adjusters help move the window closer or farther from the weatherstripping on the body. They should be adjusted in conjunction with the triangle seal. If your window seals well against the weatherstripping and your window rolls straight up and down there is no need to make adjustments.
Old Feb 3, 2014 | 09:34 AM
19GTA92's Avatar
Car: 1992 Pontiac Trans Am GTA
Transmission: 5 speed
Re: Window bumpers
Which way would I adjust those bumpers if the window is a little far out from the weather stripping? Mine hasn't been closing well for a while.
Old Feb 4, 2014 | 02:41 AM
Engine: 383 HSR EBL
Re: Window bumpers
I would be interested to know too. My window tends to rock when rolled down to certain positions while driving.
Although I suspect this is due to worn out rollers in the window guids similar to the bushings on wipers.
Old Feb 4, 2014 | 07:44 AM
82tarecaro's Avatar
Re: Window bumpers
If the window is not sealing against the outer window felt, loosen the guides (bumpers) and push them tighter against the window (towards the outside of the car) Don't make them too tight or the window will bind.
Old Feb 5, 2014 | 12:06 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Window bumpers
The service manual list the adjustment with the window halfway up.Chiltons manual also has the procedure.
Old Feb 5, 2014 | 08:44 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Window bumpers
They are called window guide/felts.
Just about any 3rd gen. parts house or fleabay have them.
Bubbajones_ya
Oct 25, 2015 08:01 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
