power door locks
Old Mar 31, 2014 | 06:56 AM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
power door locks
Power door locks work but the actuator in the door may not be working fully is my guess. But before I go taking the door panel off and replacing the actuators. Just wondering if this is a common problem or do any of thenrods get bent at all? Its the same on both side. They will lock and unlock but you have to push the button like 10-15 times it slowly works it self to the unlock and lock positions
Old Mar 31, 2014 | 07:31 AM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: power door locks
Take the panels off and observe the rod travel and operation at each point. #1 the actuator - plus all the rods are clipped in the plastic retainers/guide, if the popped out of the clips or clips broke off of door etc, a little lube wouldn't hurt either.
Old Mar 31, 2014 | 07:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds like decades of dirt and grime. The common fix is to clean and lube. I'd certainly attempt that before doing anything more drastic.
JamesC
Old Mar 31, 2014 | 07:54 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Before turning this into a big project, try cleaning the lock slides with WD40 or another cleaner and lub with some silicone. Work the slides manually until they feel smooth. Most of the time this works.
Old Apr 1, 2014 | 10:17 PM
maule6's Avatar
Car: 92 RS Camaro T-Top
Engine: 305 V8
Transmission: 5 speed manual
Axle/Gears: stock
Mine wouldn't work at all when I got the car. I popped open the panels then cleaned and oiled everything up. Now they work like new.
Old Apr 10, 2014 | 07:06 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
If oiling them doesn't work, or if you want them to really kick when you press the button, I would suggest wiring in a 4th gen bcm. Quite a bit of work, but it has a built in relay and a whole bunch of other neat features. Takes some wiring know how, patience, and time, but it is well worth it in my opinion. The old relay is horrible.
Old Apr 10, 2014 | 07:59 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Cleaning and oiling worked wonders for mine!
Old Apr 10, 2014 | 08:32 PM
Billy Brody's Avatar
Car: 1988 F-Bird
Engine: LO3 305 N/A
+1
mine do the same thing, plan on trying this over the weekend
maybe ill post up some pics of the bird too. still awaiting paint, but ive completed the repairs since getting her last fall (heater core, headliner, hood actuators, hood latch release, minor body work, weatherstripping, and last but most importantly a leaky set of coolant lines )
Old Apr 11, 2014 | 07:51 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i sprayed everything down with white litium grease.works good now.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
