Aftermarket Steering Wheels
Old Jul 1, 2014 | 02:22 AM
Hoonigan's Avatar
Car: 1986 Iroc Z28
Transmission: 5 speed
Axle/Gears: Stock
Well i ordered an aftermarket steering wheel for my 3rd gen Z28 and a quick release and hub adapter, all with 6 bolt pattern but then found out theres also a chevy 9 bolt pattern, how do I tell it apart? Just by taking the steering wheel off and hope that its 6 bolt?
Old Jul 1, 2014 | 09:17 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: Aftermarket Steering Wheels
the bolt pattern depends on the wheel you buy, you just have to make sure the spline is correct for the shaft on the column, then the length etc, etc.
the adapter slips on the shaft for the column, the wheel then bolts to the adapter using the 3, 6, or 9 bolts it requires, then the big nut and snap ring go on to hold it tight, then the horn button hides it all
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Sep 17, 2015 12:22 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
