need help!!!!
Old Sep 25, 2014 | 02:55 PM
allgonoshow88ta's Avatar
Car: 1988 Trans am
Engine: 350 tpi
need help!!!!
Yesterday be for work I grabbed something outta my truck and shut it upon returning home I noticed the trunk was half shut because something got in the way of the hydrlics keeping g it from shutting all the way now the trunck won t latch or close all all I know something probably burnt out wheather it was the fuse, motor, or solinoid i don't know currently have it zip tied shut if I'm right or wrong let me know what you think
Old Sep 25, 2014 | 03:13 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: need help!!!!
Man that was a hard read!
Hydraulics..really.........no
Solenoid...Maybe
Have you checked for power back at the pull down?
Fuse?
At least ATTEMPT to find your problem by doing a little searching on here.
Old Sep 25, 2014 | 03:30 PM
Car: 1988 Trans am
Engine: 350 tpi
Re: need help!!!!
Haha sorry didn't have time to proof read, and i checked last night there's no power coming in which is where I think it's the fuse there's also no power coming to the contact plate and all I've been able to find so far is that there a type of reset switch on the lock itself but I've yet to try it
Old Oct 11, 2014 | 08:26 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: need help!!!!
1. No reset switch for the hatch pulldown assembly.
2. Contact switch won't have power unless brake pedal is pressed.
3. Fuse for hatch pulldown is the one attached to the fuse panel but outside of the main fuses.
