Fog lamp indicator bulb
Old Dec 7, 2014 | 03:01 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
I just bought a 91 GTA and the fog lamp indicator bulb (the green one) doesn't come on when the fogs are on. Does anyone know the part number for this tiny little bulb. For those that don't know what it looks like, I attached a picture.
Old Dec 7, 2014 | 08:30 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Fog lamp indicator bulb
that is just an LED diode-radio shack or other electronic part store should have one,though you will need to remove the old one from the black plastic holder and install the new.LEDs don,t burn out from use,but they can be damaged if voltage applied without dropping resistor in circuit.The LED can be tested with a 9-volt battery and a resistor of ~500 ohms in series-also LED is polarity sensitive,will only light connected correct polarity.
Fronzizzle
Feb 9, 2017 09:31 AM
1992Z28!
Nov 19, 2015 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
