Early Third Gen Interior Swap
Old Mar 21, 2015 | 03:15 PM
BAM1988's Avatar
I have always liked the early third gen firebird interior. I have an 88 firebird, and was wondering how difficult it would be to put in an early dash and center console. I assume they are fairly similar, since everything was modular in 80's GMs. Are there any differences that I should be aware of? Will the early gauges work with the newer computer? Were the options available in the later years also available in the early ones? I don't have anything super fancy, but I do have the power latch - I've considered eliminating that anyway. Any information would be helpful.
Old Mar 22, 2015 | 04:25 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Early Third Gen Interior Swap
You will need the entire dash, the dash base is not exactly the same. The connector of the newer computer is different too, I can't say for 1988 but for 1989 is different (I have an '84 T/A and an '89 parts car). But it shouldn't matter since the ECM is on a separate harness. As for the gauge cluster, the connector should be the same but I doubt the wiring is the same.
The speedometer is mechanical on 82-84, so you will need a way to convert this.
As for the center console, the mounting brackets might be in a different place.
The plastic panels on the bottom of the dash are nearly identical, same for the hush panels.
The dash pad is different too, but compatible.
So yeah, 82-84 are a quite a bit special in that area.
Frozer!!!
Jan 19, 2024 04:55 PM
E Rod
Aug 28, 2015 05:17 AM
reiderz iroc
Aug 13, 2015 04:57 PM
bjpotter
Aug 12, 2015 06:06 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
