power window help
Old May 19, 2015 | 01:34 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
power window help
well the rivets at the top of the motor have all but completely torn though the metal. and its ringing the hole out pretty good. so i heard i could just drill the rivets out and put bolts plus some big *** washers on to fix it. sooo true? if so do i need to worry about anything?
Old May 19, 2015 | 07:12 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: power window help
Sorry to hear. I replaced my motors with the bolts instead of the rivets. I used grip washers to keep them from moving around in the holes in the door once tightened up. That may be difficult to accomplish if the sheet metal is boogered up on yours. Can you weld? Seems like it would only need to tack the holes back together or even tack some washers over the offending holes.
Old May 21, 2015 | 10:42 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Yes you can use bolts,I just received a new pair that included a new set of bolts.Don't know if I'm going to use the bolts or just re- rivet them.
Old May 21, 2015 | 09:10 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
Yes..You can use nuts and bolts. My suggestion to you is to use smallest sizes you can and definitely use a nylock nut, or threadlock..getting your hand behind and on the nut is no fun..and you only wanna do it once ...if you are having tuff time locating nut on, use some vaseline or similar to hold it on the tip of your finger to place on the bolt....i followed the instructions found on the site to install new motors, and they worked flawlessly..if you were near me, i'd help.
Old May 22, 2015 | 07:19 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
When I did mine I found a strip of plastic and hot glued the nuts to it. Then I fed the plastic stick with nut attached behind the door where my hands wouldn't fit. It's a royal pain in the a$$ of a job. Good luck.
Old May 23, 2015 | 10:01 PM
DARKmj16's Avatar
Engine: 305 tbi
ima try to work on it tmrw. wish me luck. ill look at the instructions on here, maybe i should just get new motors lol.
Old May 24, 2015 | 03:55 PM
DARKmj16's Avatar
Engine: 305 tbi
i dont think this is the window motor, but what is it, the regulator? regardless i need to do something about these, ideas?
Attached Thumbnails power window help-img_1181.jpg   power window help-img_1182.jpg
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
