Shifter gear indicator led
Old Jul 15, 2015 | 04:53 AM
NiG's Avatar
NiG
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Hi all,
I dont know if this subject has already been covered, but mine is a simple question. This car have some leds that indicate the gear/mode you are using, in the shifter plate.
Is there any way in the pre-1990 cars to obtain such a feature?
At least, in 82-90 cars, is it possibile to figure out when you are in D and thus activating a led?
It would be very usefull.
thanks!!
Old Jul 16, 2015 | 10:10 AM
FirebirdUSX's Avatar
Car: Firebird
Engine: 5737cc
Re: Shifter gear indicator led
My car has a light...i thought all cars have a light there.
Old Jul 17, 2015 | 07:52 AM
NiG's Avatar
NiG
Engine: 5700cc
every car has a light there, but the one in picture has an additional led indicator that tells you your actual gear. Mine (1989 GTA) doesnt have it. It just have a light :/
Old Jul 17, 2015 | 12:16 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Wiring something up shouldn't be too hard. Run + to a series of LEDs and install a small spring steel trigger on the - side of each one. Then just mount a metal arm on the shifter mechanism to contact each piece of spring steel to complete the circuit for each LED in turn as you move the shifter. Mounting it and getting it aligned would be the hardest part.
Old Jul 20, 2015 | 11:33 AM
NiG's Avatar
NiG
Engine: 5700cc
so you say that this part (with indicator LEDs) is compatible with a pre-1990 firebird? That is, I can buy one and mount it on my 89 GTA?
The manual procedure you pointed out seems kinda complex
thanks!
Old Jul 20, 2015 | 03:34 PM
Car: Firebird
Engine: 5737cc
thanks!
i guess its cheaper to simply buy the whole console with the lights and everything plus I'm sure in the future is not bad to have a spare.
Hotrodboba400
Dec 10, 2019 07:07 PM
GouldyGTR
Sep 7, 2015 09:05 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
