short in courtesy module
Old Oct 13, 2015 | 06:20 AM
coren's Avatar
I am blowing 20 amp fuses from the main fuse panel on the Acc port. What are the first things that I can check?
Old Oct 13, 2015 | 03:45 PM
coren's Avatar
Re: short in courtesy module
To be more specific, car is 1986 Camaro iroc z; been sitting for 11 years and I am not only restoring it, but building a 350 full race engine with twin turbos for it. My short is obviously in the circuitry for the courtesy module. Not sure whether problem is in wiring for cig lighter, interior lights, alarms for lights on, door open, etc. but I am asking for advise as to where to start first.
Old Oct 30, 2015 | 10:42 AM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
It's possible the power outlet in the center console is shorting out. The terminals often become corroded and then cause the fuse to blow. Unplug the connectors and see if the fuse sill blows out.
Old Nov 2, 2015 | 10:16 PM
stalkier's Avatar
Engine: 5.7ltr
Transmission: 700r4 with shiftkit
Axle/Gears: LS 4.11
Im having the exact same issue in my 1988 Trans am 5.7
Old Nov 3, 2015 | 11:18 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Is it blowing them as soon as you put them in or does it take a while?
norcalz28
Jan 16, 2017 03:37 PM
CRAZYCHUCK13
Exterior Parts Wanted
Oct 18, 2015 06:54 PM
EvilMunky707
Interior Parts Wanted
Oct 18, 2015 03:22 PM
86IROC112
Oct 13, 2015 12:41 PM
Brycelago
Oct 6, 2015 11:50 AM
