How to access door handle without opening door?
Old Oct 31, 2015 | 06:20 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
So the most amazing of situations just happened to me. My interior door handle drivers side snapped and would no longer work. I ordered a new one yesterday, today, as luck would have it, my exterior door handle also snapped... So, now I have no way of opening or closing my driver side door. does anyone have a good strategy for opening my door so I can actually replace these parts? any help would be much appreciated
Old Oct 31, 2015 | 06:36 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Re: How to access door handle without opening door?
pull off the bezel inside the car and pull on the rod
Old Oct 31, 2015 | 07:20 PM
Dabesiv's Avatar
appreciate it man, I'll see what I can do with it tomorrow.
Old Nov 2, 2015 | 04:45 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Just roll the window down and then standing outside the car with a good
flashlight look down inside the rear of the door.
Look for the handle to latch rods.
Use a strong wire or rod to grab the handle rods and pull it up
to release the lach and open door.
Old Nov 13, 2015 | 04:56 PM
Dabesiv's Avatar
So my parts finally came in and I attempted to open the door with a wire, no luck, tried the mechanism for both outside and inside handles. I was able to pull off part of the door trim and get my hand on the mechanism but cant tell what i am feeling, but it appears as though the mechanism is broken. Am I SOL and taking the car to an actual shop or is there a workaround I can do?
Old Nov 13, 2015 | 06:21 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
They may not do much more than what you're trying now. Even worse if they're not familiar with older vehicles like ours.
I think you may be able to use something like a yardstick but metal if you can find something similar. If you see how it moves you should be able to go through the window slots and push down on the tab. Sorry if that's not clear, have other things on my mind right now.
Old Nov 13, 2015 | 07:01 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Top rod is door release and the bottom one is for the door lock.
Inside of the door looking at the latch mechanism. Push down on the door handle rod to release the door.
Hope this helps...
Old Nov 13, 2015 | 07:14 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Look down inside the door on the other side, see what moves when you pull the door latch.
Old Nov 14, 2015 | 09:12 AM
Dabesiv's Avatar
thanks for the quick replies guys, I have looked at the other door to see how it works, but neither way is working on this door, pushing down or pulling the rod, it's starting to worry me
Old Nov 14, 2015 | 03:33 PM
jharrison5's Avatar
Car: '87 IROC
You didn't happen to lock the door while messing around in there did you? I have messed with a stubborn door before just to realize the door kept locking as I reached in lol!
Old Nov 14, 2015 | 03:57 PM
Dabesiv's Avatar
haha, I did the first time around and was careful to make sure it was unlocked after that
Old Nov 15, 2015 | 01:23 PM
Dabesiv's Avatar
Got the door open today after some intense disection of the door. The lock wasn't the problem, the latch was jammed but I got it free enough to release the door. the latch no longer works though so a new one is on its way. i appreciate the help guys
Old Nov 15, 2015 | 01:48 PM
alex722607's Avatar
Was it rusty? Or was it just frozen on the inside. I've rarely heard of this happening which is why I am curious
Old Nov 15, 2015 | 03:07 PM
Scorpner's Avatar
Engine: V6, V8
Congrats! Good to hear.
Old Nov 15, 2015 | 11:19 PM
Dabesiv's Avatar
it's not fully removed yet, but it looks rusted and I can see the spring for the mechanism is disconnected and bent out of shape.
Old Nov 16, 2015 | 05:45 PM
jharrison5's Avatar
Car: '87 IROC
Great to hear that you were able to get the door open! Now the fun part of cutting the hell out of your arm while changing out the latch!
MantyZ28
19
Nov 24, 2015 11:10 AM
89irocz355
Exterior Parts for Sale
Nov 18, 2015 10:18 PM
NiG
Nov 13, 2015 07:10 PM
89irocz355
Nov 5, 2015 03:55 PM
89irocz355
Oct 29, 2015 09:55 PM
