1985 Dashboard
Old Feb 23, 2016 | 07:37 AM
Chough262's Avatar
Car: 1985 Trans Am
1985 Dashboard
I have a project underway and I am wondering if the dash from a 1990 firebird is compatible with a 1985 Trans Am. I will be converting to manual gauges. I am just wondering if I can simply put the 1990 dash in and all the screws/bolts will line up? Thanks
Old Feb 23, 2016 | 08:26 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: 1985 Dashboard
All of that should be the same. They used the same cluster design since at least 85 and did not change thru 92.
Old Feb 28, 2016 | 06:42 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: 1985 Dashboard
There are some differences between 85-89 dashes and 90-92 with airbags. Most of it is the same but the lower edge on the drivers side has different brackets for lower panels because of the air bags.
It still mounts to the chassis the same.
I have a 85-89 dash in perfect condition for sale.
I have pics of both to compare but have to get to my computer, on the road today.
Old Feb 28, 2016 | 08:52 PM
Onion's Avatar
Re: 1985 Dashboard
Wow that is pretty neat. Didn't know that the mounts are the same. I guess Camaro was the only bastard child when it came to dash mounts
mattbhm
Apr 24, 2016 09:08 AM
nobull5
Firebirds Wanted
Mar 28, 2016 07:34 PM
LB9GTA
Mar 6, 2016 09:46 PM
birdman53
Feb 4, 2016 12:38 PM
anakko
Jan 25, 2016 12:50 AM
