85 Berlinetta Tilt Column Parts
I bought this car new, and I have worn out the tilt lever release lever inside the column - it is not repairable and no replacement exists, that I have found. Does anyone know where this part is available? This column ONLY has the tilt release on the left side (nothing else) and uses a flat 'Z' shaped lever - the insert inside the column is cracked. Any help would be appreciated - even a working column would suffice as long as it is for the Berlinetta. See attachments.
Thanks in advance.
Thanks in advance.
Last edited by VeryTired; Mar 6, 2016 at 07:16 PM. Reason: i forgot to upload images
Re: 85 Berlinetta Tilt Column Parts
Thanks in advance.
Thanks in advance.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Not sure if I've got small parts to rebuild your original, but I've got a replacement column or 2,.... Let me see if I can find the small part you need. I'll re-post once I know for sure.
I checked,..... I do not have this part. If you need a complete column get back to me with your Zip code and I'll reply with more info ! Be sure to specify Cruise Control vs. no Cruise & auto vs. manual - obviously WITH tilt !
Thanks John in RI,
I have visited your site many times out of curiosity. Right now I am trying the "JB Weld" solution wrapped in aircraft safety wire .............. it looks promising, I'll know after it cures a full day.
If not - I will send you an email.
hotrodjames
Mar 23, 2016 02:05 PM
mclenty0
Mar 8, 2016 11:57 AM
mawaleegulu
Exterior Parts Wanted
Mar 4, 2016 12:19 AM
Dads91camaro
Interior Parts Wanted
Mar 2, 2016 06:34 PM
