Rear seat belts
Old Mar 15, 2016 | 10:20 PM
dad24doys's Avatar
Car: 1987 Camaro Iroc Z
Engine: 5.0 TPI
Transmission: Automatic
Rear seat belts
I have small kids and my wife is not real keen on them riding in the back of my 87 iroc (once I get it running) with just the lap belts.
Has one converted to the typical belts we have now? Shoulder and lap? Where to buy them?
Thank you
Old Mar 16, 2016 | 10:02 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Rear seat belts
They started installing three points seat belts in the rear in third gens in 1988...so close :P
Either get a 1988-up or find a parts car that has what you need : welded brackets, rear belts, interior panels, seat belt guides for the rear seat.
Old Mar 16, 2016 | 10:03 AM
dad24doys's Avatar
Engine: 5.0 TPI
Re: Rear seat belts
Thank you. I will start looking and I found a guy in my area that does interiors and I am going to call and see if he can install. I do not know how to weld
Old Mar 16, 2016 | 02:22 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: Rear seat belts
You'll probably want a later thirdgen, or 4th gen rear seat, for the seatbelt guides that were built into the seatback.
Old Mar 16, 2016 | 02:30 PM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Re: Rear seat belts
I have a full set of 4th gen belts for sale if you're interested
Old Mar 18, 2016 | 08:53 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Rear seat belts
The Seat Belt retainers that get screwed to the rear seat backrest ) part of the rear seat belt assembly. The belt is fed thru the retainer and as far as I know,... there is no way to separate it from the Rear belt assembly unless the belt is cut. ( I have a spare set of these retainers,.. but seem to remember cutting the belt in order to remove the retainer. )
I've got a set of the brackets needed for the rear shoulder belt conversion. I might also have the Rear Belts and hatch plastic Panels too depending on the color you need. If you're seriously interested in converting and need more info send me a PM for details. Be sure to include the interior color and your ZIP code.
jeremy iroc z28
Jun 25, 2016 01:34 PM
85@IRocZ
Apr 3, 2016 06:01 PM
ray jr
Mar 25, 2016 10:02 AM
usmechanix
Mar 20, 2016 12:14 AM
Brian Anderson
Wheels and Tires
Mar 15, 2016 07:17 PM
