gutting dash which electrical compnents can I unplug
Old Mar 19, 2016 | 10:09 AM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
like it says I am gutting my dash off all the heater ducting and I ran into some electrical boxes on the passenger side I was just wondering if I could unplug them and be done with them or it the would mess with the ecu/ guages
Old Mar 19, 2016 | 10:37 AM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: gutting dash which electrical compnents can I unplug
ECM is under the right side dash, so is the timer relay for rear defrost if you have it. Also relay for power antenna.
Old Mar 22, 2016 | 12:19 PM
nuggie's Avatar
I ran into what is labeled GM passkey? what the heck is that
Old Mar 22, 2016 | 12:39 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
More commonly known as VATS, or Vehicle Anti-Theft System. You'll have to bypass it if you want to remove that. Not hard to do though.
3rdgenparts
Jun 16, 2016 09:16 PM
cal30_sniper
Mar 17, 2016 12:01 PM
astout82
Mar 15, 2016 09:20 AM
trafficlightguy
Mar 15, 2016 03:10 AM
92firebirdchris
Exterior Parts Wanted
Mar 14, 2016 08:42 PM
