Dash lights blink but turn signal doesn't
Old Mar 28, 2016 | 08:59 PM
Brian28166's Avatar
I am putting my son's 88 IROC back together. Down to putting the gauge cluster back in. Replaced dash lights with LEDs left the regular bulbs in the warning lights and turn signals. Everything is working except the passenger side turn signal indicator. Turn on driver side dash lights don't blink turn signal does. Turn on passenger side no turn signal and right side dash lights blink. Can someone help me with? Forgot to mention that the passenger side trunk signal indicator bulb is very dim with no turn signal...
Old Mar 29, 2016 | 10:52 AM
Zarathustra's Avatar
Car: 1987 Firebird Formula
Re: Dash lights blink but turn signal doesn't
Hello Brian. Was the passenger side turn signal indicator working before you removed the instrument cluster?
I had a very similar issue: passenger signal indicator AND signal itself only worked in cool weather, nonfunctional when hot. Furthermore, with headlights on the passenger signal indicator would illuminate permanently (not flashing) and front turn signal would not function, but rear turn signal did.
Long story short, I replaced the turn signal switch (inside the steering column) and all of my problems were solved. I think some water had infiltrated the steering column when I got rained on while driving with T-tops off.
Hope this helps, let me know if you have a question.
Old Mar 30, 2016 | 03:09 PM
project28166's Avatar
THANKS FOR THE INFORMATION. TO ANSWER YOUR QUESTION THE CAR WAS IN PIECES WHEN I GOT IT. IT HAS BEEN A JIGSAW PUZZEL. I HAVE TO CHANGE THE IGNITION KEY SWITCH AS WELL AS TIGHTEN UP THE TILT STEERING.
Krazzycowgirl
Pacific Northwest Region
May 25, 2016 06:22 AM
Clint's 86
Mar 5, 2016 11:56 AM
Xzavior1818
Mar 2, 2016 04:49 PM
SteelheadBen
Feb 29, 2016 09:06 AM
