Windscreen wiper jerks
Old Sep 5, 2016 | 11:36 AM
NiG's Avatar
NiG
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Hello
Both my (brand new) windscreen wipers jerk. They dont move smooth at all. Very ugly, it gives a very bad image of the car
a video of mine:
Is it normal?
How can I correct it?
THANKS!!
Old Sep 5, 2016 | 03:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Windscreen wiper jerks
Just my due centisimi....
1. Make sure the windshield is CLEAN. The glass is clean when the water sheets off the glass and does not bead. If you can find Bon-Ami powder in Italy, this works well for cleaning glass.
http://www.bonami.com/index.php/prod...wder_cleanser/
2. Replace the rubber squeegee if you haven't done this already.
3. Sometimes the spring tension in the wiper arm gets weak. New wiper arms is the only remedy for weak tension.
Old Sep 6, 2016 | 09:45 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I've seen a lot worse, yours look pretty smooth.European wipers must be fantastic.
Where exactly does it jerk?
