88 gauge cluster formula
Old Sep 6, 2016 | 10:08 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I have just got a 88 formula w/350tpi.no motor or engine harness. I have a motor and harness from a 87 I think. Motor block may be a 88. The harness has no wires for the speedometer. This car has a vss box under dash and no mechanical cable coming through the fire wall. 140 cluster. Any in 88 come. MAchanial or they all impulse? Or I need a 88 engine harness.I got a TBI camaro with mechanical spedo
Old Sep 6, 2016 | 10:13 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: 88 gauge cluster formula
your bird has digital electronic speedo. not mechanical
Old Sep 7, 2016 | 07:07 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The motor and matching wiring harness you already have from an 87 (you think) was probably from a 87 Camaro; and that's probably why there is no electric speedo wiring.
The 88 Formula has an Electric Speedo sending unit,....... regardless of the type of cluster.
Old Sep 7, 2016 | 09:44 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Your right the harness was from a z28. There's a vss buffer box near the ecm mount area. If I want my spedo to work I need a firebird ecm? Or just run wires to the buffer?
Old Sep 8, 2016 | 09:25 AM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Go to: https://www.thirdgen.org/technical-articles/ In the Miscellaneous Modifications is an article titled: Swapping an electric speedometer into your Firebird (off-site) This should help. Sorry, locked out of the article on my work computer.
Old Sep 8, 2016 | 09:56 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
OK. Sence my car already has the gauge cluster vss box and dash wires all I got a do is pull the wires from an electric type sender to the vss box.from what I gather from this, is the vss signal has nothing to do with the ecm its self.
Old Sep 9, 2016 | 12:28 AM
John in RI's Avatar
These are from an 88 Firebird Shop Manual:
This is the C100 connector,... All you need to do is install the proper Electric sending unit ( with the correct Speedo Gear ), then find the proper plug with wiring and lead it up to the C100 connector however you desire. ( poke the 2 wires thru a small hole in the firewall, Ect.... ) You can cut/splice into the C100 wires under the dash and then the Cruise Control, ECM & Cluster will get the electric VSS signal as factory designed.
PINS/Wires = 'D4'/YELLOW and ' E4'/PURPLE
P.S. The Electric Speedo Sending Units for your car can be hard to find. Used from 84-89(?) on Berlinetta, Firebird and Vetts. Speedo gears are also electric and cable specific so be sure that you get the matching speedo 'DRIVE' gear too !
Old Sep 9, 2016 | 06:46 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
K. Thank. I will have to get on my home computer so I can print that info for my folder.
Chf.BurninGlass
Jul 10, 2016 12:07 AM
propaintball96
Members Camaros
Mar 25, 2016 11:48 AM
JL2000
Mar 16, 2016 05:26 PM
astout82
Mar 15, 2016 09:20 AM
Sals82Z28
Aftermarket Product Review
Jan 17, 2001 10:55 AM
