Digital Dash Bulb change
Old Sep 16, 2016 | 07:51 AM
Smackdown's Avatar
Car: 88' GTA & 89' T/A
Engine: 350 TPI & 305 TBI
Transmission: Automatic
I've a digi dash and I nee dto change some bulbs of the control center, where I can see the Mileage, current Trip etc. Where do I begin and how do I change the bulbs? can someone please help me, I don't want to break smth so I want to do it right the first time.
Thanks!
Old Sep 16, 2016 | 09:50 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Digital Dash Bulb change
Cehbra lives in Switzerland and seems to be the digital dash guru around here, have him do it, lol
Old Sep 18, 2016 | 02:56 PM
Cehbra's Avatar
Car: Red 1991 Firebird with digital dash
Engine: L03 V8 TBI
Transmission: 700 R4
Captain incoming, lol Just kidding, I don't even have a digital dash in my car yet.
What I would do is remove the dash pad first. There are several screws on the underside plus three on the top inside the vent. Gives you a little space to work more freely.
Then there are a few screws to the two beauty bezels to the right and to the left of the digital cluster and some on the cluster itself, remove them.
It should not be too big of a problem to remove the whole cluster out then. If the wires to the DIC are too short see post #61 and below from mikedin in my digital dash thread:
https://www.thirdgen.org/forums/elec...86-88-a-2.html
When you have the cluster out you don't need to open ist. On the back you'll find 4 twist on bulb plugs which can hold a 194 / T10 wedge bulb. Just screw them out from behind and replace the bulb. There are 7 small ones, too (for turn signal, high beam etc.). These are kind of difficult to unscrew as there's a little plastic lip that has to be raised with a small screwdriver tip first.
Then redo all of that in reverse order.
Hope it works.
Old Sep 18, 2016 | 03:00 PM
Cehbra's Avatar
Engine: L03 V8 TBI
Here's a pic I took some time ago. It shows the twist on plugs.
1Aauto
Sponsored Vendors
Nov 29, 2016 02:41 PM
MeenZ28
Southern California Area
Oct 12, 2016 09:29 AM
Steve Ochoa
Sep 30, 2016 04:18 AM
1Aauto
Sponsored Vendors
Sep 19, 2016 08:11 AM
Piotr Zaborniak
Sep 15, 2016 10:19 AM
