How do I go about getting new keys?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: How do I go about getting new keys?
If you have a VATS key you might not be able to go to just any hardware store. You probably have to shop around a bit.
You can measure the key resistance yourself (internet search for a DIY) and buy blanks on your own then have them cut.
IMO, your best bet would be a locksmith.
Car: 86 Iroc Z-28
Engine: 5.0 TPI
Transmission: Automatic
If you're wondering about the little "security chip"; I took mine to a Chevy dealership and they had the machine to remove it then put it back on when they were done.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The auto parts stores, hardware stores and walmarts may have the key blanks but like said you will have to measure the resistance of your key and find a key that matches the resistance. This could mean measuring lots of keys. Best bet is going to be a Chevrolet dealership. As far as the exterior key goes any place that cuts keys will work fine.
Thank you!
