Repairing headliner board
Car: '87 GTA
My headliner was sagging and the fabric literally falling apart. No big deal, got the whole thing out and removed the damaged fabric.
Any ideas on how to repair the headliner board? It's kinda rough in the area where the seatbelts go through, still all in one piece, but not very solid. Just tape it on the top? Glue? Any ideas?
I'd like to give putting on new fabric a try before paying $300 for a new one..
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Repairing headliner board
A thin layer of fiberglass resin all over the board will strengthen it.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Use a little fiberglass cloth where the board is really damaged. Just be sure not to add too much material and weight as it will wind up too heavy. There are only a few clips and the back trim piece holding it up.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I found an old headboard at Pick N Pull and used the fiberglass trick on the hole back.
Then sanded the other side until it was completely smooth to the touch.
Sprayed it with adhesive and slowly unrolled a piece of nice black vinyl over it.
Came out OK. I like the black vinyl because its easy to keep clean and it matches my "Door Skins" , "Rear Sail Panels" and "Kick Panels".
