Door Arm Pull Screw
Old Mar 9, 2017 | 01:21 PM
jax0687's Avatar
Car: 1992 Chevy Camaro RS
Transmission: Automatic
Door Arm Pull Screw
I am trying to figure out what size torx screws I need for the upper hole on the door arm pull. I have a 92 Camaro and just need the long screws but am having no luck figuring out the size. Thanks in advance
Old Mar 9, 2017 | 01:47 PM
Drew's Avatar
Re: Door Arm Pull Screw
How many do you need? Theyre probably not something you'll find at the local hardware store, and most online places will probably make you buy in bulk. If you only need 2 or 4, you're probably further ahead to go junkyarding, or ask in the classifieds here. I'm sure someone probably has a few to spare.
Old Mar 9, 2017 | 01:51 PM
jax0687's Avatar
Thank you Drew, I am just needing one. I found one in a junk car, I will check the classifieds and hit a few junkyards
Old Mar 9, 2017 | 06:33 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
If you haven't found one already, PM me your address and I'll send you one.
