B&M Street Bandit Shifter Configuration
Old May 14, 2017 | 04:36 PM
Brianb4's Avatar
Car: Corvette drivetrain Austin Healey
Engine: Mild 350,FirstFuel TPI, Fast EZ ECM
Transmission: 700R4, Shift Kit
Axle/Gears: 2.73 Ford, 8.8
I bought an Ausitn Healey kit car built in 1990. It has a 700R4 trans in it. The shifter performs as follows:
Shifter 1st Gear: Actually 1st and 2nd
Shifter 2nd Gear: Actually 3rd gear
Shifter 3rd Gear: Actually overdrive
Can this be changed so 1st and 2nd are controllable and 3rd and 4th can shift out on vacuum?
Thanks Brian
350, 2032 crane cam, 1.5 comp cam roller rockers, corvette aluminum heads,FirstFuel TPI injection, Fast EZ ECM controller.
Old May 28, 2019 | 06:06 PM
chilliewillie's Avatar
Re: B&M Street Bandit Shifter Configuration
As far I as I know the 700r4 shifts by T. V. (throttle valve) cable and that goes up to your accelerator linkage. Sounds to me that your shifter isn't designed for 4 speed. Just put a Hammer in my 90 corvette and it has a pin you knock out to make it work for a 4 speed. Other wise it works for a three speed.
