unknown interior piece likely under dash
Old Jun 3, 2017 | 03:22 PM
tom1985's Avatar
Car: 85 Camaro /65 Lemans
Engine: 305 vin H / 396-375 hp (Real)
Transmission: 700R4 / 4sp
Axle/Gears: 3.08 posi / 4.88 posi
Hi all,
Don't remember where these go and just starting to reassemble gutted interior (85 camaro sport-and what fasteners needed to attach them?
thanks you
tom
Old Jun 3, 2017 | 04:23 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: unknown interior piece likely under dash
Google'ing PN 14039445 shows them to be radiator baffles... the close out panels to the left and right of the radiator, extending forward from the radiator support to the nose-ish area.
Courtesy of wholesalegmpartsonline.com
Old Jun 3, 2017 | 05:24 PM
tom1985's Avatar
Thanks Mojoe
I would have never figured out and would have spent some time upside down under the dash (not easy at my age/flexibility. Now it appears to be a "nice, but not required item as the engine compartment is basically done already.
Also, nice picture of components. Also, this type of components picture "should" be in the original GM manuals on a larger scale (I have the 85 camaro shop one) and GM should have documented every fastener used on each piece, I wish. It seems like the sheet metal and other critical components/fastener info to put together the car are brushed over and disorganzied it seems at least in my 3 inch manual, mainly auto trans and emissions stuff. Thank god i removed the emissions
tom
