Replacement door latch spring
Old Jun 15, 2017 | 06:28 PM
nbressette's Avatar
Just wanted to share that if you're looking to replace the door lock spring on the door latch you can use one from a Land Rover.
After soaking my door latch in rust remover for a few days the old springs just disintegrated. two of the 3 springs were available at the hardware store but lock spring is special and could not be located anywhere I looked. These from eBay worked perfectly. A new latch was ~$100 so $5 in springs saved me a bit of cash.
http://www.ebay.com/itm/New-5-x-Repa...-Discovery-MK1
