T Top storage question.
Hey all, I recently got an 89 Camaro and the t top storage bag is missing the rear straps for mounting the bag to the rear bracket. Could anyone point me towards a suitable replacement for them?
Thanks.
Thanks.
Car: 1986 Trans Am WS6 w/ Recaros
Engine: LB9
Re: T Top storage question.
Check out Hawksmotorsports
T-Top bag used.
http://www.hawksmotorsports.com/82-9...p-bag-gm-used/
T-Top bag reproduction.
http://www.hawksmotorsports.com/cama...-reproduction/
T-Top bag used.
Engine: LS1, LB9, L03
IIRC the straps are sewn on to the bag, so finding straps by themselves is probably not going to happen.
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
if you've got the straps that attach it to the boot/ truck floor but missing the ones that go to the back of the boot (just behind the rear lights), then I suggest getting some thin luggage straps so you can loop these through and then use the plastic clips to hold into place
Engine: LB9
