NEED HELP WITH DASH LIGHTS
Old Jul 20, 2017 | 10:54 PM
Coz2122's Avatar
Dash lights come on when brake is engaged. When car is off and brake is engaged the dash lights come on and the headlight buzzer sounds. Ground wire is connected firmly to steering column. Any help would be great thanks
Old Jul 24, 2017 | 09:18 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: NEED HELP WITH DASH LIGHTS
There's a short somewhere between brake lights and driving lights. It's usually in the tail light harness or lamp. Once I had a two pole bulb melt the poles together, both lights worked, but cross connected them.
