Help! Noise in passenger footwell while AC is on and I brake
Old Jul 21, 2017 | 03:23 PM
djdsails's Avatar
Car: 92 camaro RS
Engine: Moded 350 engine
Transmission: 5 speed
Hi
So whenever I press the brake while I have the AC on a weird low pitched hissing and low pitched fluttering sound occurres. It stops when I stop braking and it stops when I change it off max AC. This is probably a vaccume issue. There was one point I had to much vaccume on it after the engine swap to carb and also it sometimes if I leave it on bi-level it gets stuck when going from bi-level to off, a little snap occurres whenever I make it go off. While car is off the mode sliding bar sounds normal. Slight hissing noise occurres when i go from any position to off. All the modes do what they are suppose to do, ie the air is properly directed.
I don't know the vent system well so any direction would be great
Help!
Thanks!
Old Jul 21, 2017 | 05:16 PM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
Re: Help! Noise in passenger footwell while AC is on and I brake
its a vacumm leak in the controls. there is a video in this thread:
https://www.thirdgen.org/forums/cool...ac-heater.html
or to buy a replacement valve:
http://www.top-downsolutions.com/ind...category_id=67
Old Jul 21, 2017 | 05:28 PM
djdsails's Avatar
Car: 92 camaro RS
When I go to the off position and it getting suck makes sense that the rotary valve needs replacing. But does that explain the noise in the passenger footwell when I brake and the ac is on max?
Thank you for the link!!
