Speedhut fuel gauge help
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
I can't get my gauge to give me the correct fuel level the factory sender is 90ohm from what I understand but I have tried all of there ohm settings and none seem right to the guys running these gauges how are you setting them up?
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Speedhut fuel gauge help
I have mine setup per the provided instructions. Did the oem fuel gauge work before you swapped over the the speed hut unit?
Car: 92 camaro RS
Engine: LSA
Yea it worked before hand I'm going to pull the cluster and recheck all the grounds I'm having a temp issue as well now.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You can also do a custom calibration, but you'd have to do it manually w/ the pump out of the tank.
Car: 1991 Z28 Vert
I would use a multimeter to check the ohm reading of the wire behind the rear seat before the cabin connector. That will tell you for sure if the sender is working correctly. If it is then you can pull the cluster and probe the connectors.
