size of seat track nut
Car: 1986 Z28
Engine: 383 Stroker
Axle/Gears: 10 bolt 3.73 limited slip
Trying to get the drivers seat out of 86 Camaro.
nuts are rusted up pretty good on the floor mounting studs
been soaking in penetrating oil, next step may be a wrench and low pressure air hammer
after that may just try and split the nuts.
anyone have idea on size of threads on the 13mm nut?
thanks
Dale
thanks
Dale
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: size of seat track nut
Have you tried PB Blaster?
I’ve always had good luck freeing up rusted pieces with that stuff.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 1986 Z28
Engine: 383 Stroker
thanks for the info!
been blasting them with pb blaster, no luck
going to try a mixture (50/50) of atf and acetone this week
Dale
Dale
Maybe try one of these craftsman nut crackers:
http://m.sears.com/craftsman-nut-cracker/p-00904772000P
Axle/Gears: 10 Bolt 2.73 Open
