Plastic carpet glue removal, is it necessary
Old Oct 23, 2017 | 06:35 PM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
If I am dyeing my interior plastic and re-carpeting the pieces as well, do I really need to spend the time scraping the old glue off or am I just being lazy????
Attached Thumbnails Plastic carpet glue removal, is it necessary-img_0073.jpg
Old Oct 23, 2017 | 07:30 PM
Drew's Avatar
Re: Plastic carpet glue removal, is it necessary
The factory obviously didn't care what it looks like under the carpet....
Odorless Mineral Spirits might dissolve that stuff. Not the sissy water based, Sierra Club approved ****-water, but regular old odorless mineral spirits. Works on about 75% of the gunk found inside a thirdgen. Mild enough it shouldn't hurt most things, but test it first someplace where a flaw won't be visible.
Old Oct 24, 2017 | 10:20 AM
Car: '89 Iroc
Engine: 383 TPI
Exactly. Still have to clean and prep the piece properly but am planning to not bother with glue removal, besides whatever comes off during cleaning
Old Oct 29, 2017 | 03:59 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I would not go through the process of re carpeting without at least trying to remove it, at the very least with some "Goo Gone".
Be sure to soak it for a few minutes.
Old Oct 29, 2017 | 04:59 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I used my heat gun on low and peeled it off gradually. It took most of it off ad then I just spray dyed around where the carpet was going to cover.
