air bag wire
Car: 1990 camaro
air bag wire
I have a 1990 rs camaro. I'm installing a aftermarket grant steering wheel. I removed air bag. This may be a dumb question but what do you do with the airbag wires?
Re: air bag wire
Cut the wire under the airbag coil, grab the connector under the column and pull the yellow wire out. Throw away the sensor under the hood latch, behind/under the radio, and in the center console. Throw out the control module under the passenger's side of the dash.. Deleting all the wiring is a bit of an exercise, I don't really recommend it.
