Interior Rear Molding
1984 Z28. What is the best way to restore all of the plastic / vinyl molding in the rear half of the car? It's all pretty faded, can it be cleaned, and painted?
Thank you
Kevin
Thank you
Kevin
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Interior Rear Molding
My
Save yourself the time, energy, and $$ and just buy some good used original panels in the color you need.
Cheap Spray dye is about $10 a can and good Spray Dye is about $15 a can. If you put in a bunch of hours cleaning / prepping / dyeing the original faded & deteriorating panels the results are always great - till the panel gets scratched. A couple years later and you'll be wishing you just got some decent used panels in the first place.
:Save yourself the time, energy, and $$ and just buy some good used original panels in the color you need.
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
I just re-did my plastic interior. I used SEM paint for plastic. They came out GREAT! You have to figure out what color you will need that closely matches but it matches up nice. First I washed all my parts with dawn dish soap and water. After I let them dry I used the SEM prep to plastic. You spray it on then wipe it off right way. Then painted them, 3 coats, of the factory color from SEM. Waiting10 minutes in between each coat. After that I sprayed them to 2 coats of the SEM Satin finish. I could not be more satisfied.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Finding good replacements local sometimes aint possible.
Esp. if you live in the sunbelt !
I just washed and dried it , a bit of EASY on the Scuffpad action and just Armoralled it.
Buffed w/ compound on the outside.
Good luck!
Good luck!
What color do you need,... what is your ZIP code ??
Generally speaking; this website, craigslist, E-Bay, & Facebook are the best online searches you can use. The alternative is the 'old school' method of searching thru the local bone-yards. There's not much left in most yards these days - but you can get lucky sometimes !
