Retractable cargo cover
Old Apr 19, 2021 | 09:11 AM
Jacques101's Avatar
Car: 1984 &1987 Firebird, 1991 GTA
Engine: 5.0(84) , 5.7L LT1 (87),5.0(91)
Transmission: Automatic
Axle/Gears: 3.23;3.42;2.73
Has anyone ever successfully retensioned a retractable cargo cover? I have one that everything is intact but it needs to be rewound. Do you know what the procedure is to tension springs inside the shaft?
Old Apr 19, 2021 | 02:50 PM
Swapper's Avatar
Re: Retractable cargo cover
i have an extra one that i was goin to try and do what this guy did but trying to read through the steps just made my head spin and i ended up just buying a working one.
https://www.thirdgen.org/forums/inte...acy-cargo.html
Old Apr 19, 2021 | 04:13 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Try mounting it on the car, if you pull the cover out while removed it wont retract. It needs to be on the car or if you press in the ends while removed it will also pull the cover back in. Unless its actually broken.
MARO-MAN
Dec 17, 2006 11:35 PM
rjpbboi
Nov 30, 2005 04:21 PM
MrJ
Feb 19, 2003 06:35 AM
