New to me. 91 Z28
Old Mar 19, 2022 | 04:22 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
New to me. 91 Z28
Hello, I'm new here. I've been lurking for about a year. I picked up a 91 Z28 today so I have some questions. I need ( would like) a OEM steering wheel complete assembly to replace the aftermarket the PO installed. Any danger of installing with the air bag?
I also need the driver seat. Bad tear. Can a passenger seat be used if you switch the tilt forward device? Can you switch the tilt forward device?
The steering wheel turns harder than I think it should and when you turn the wheel just a little going down the road it doesn't come back to center. Ideas on what's wrong? Bad ball joints?
Old Mar 20, 2022 | 06:38 AM
BBCSwap's Avatar
Re: New to me. 91 Z28
Did I post this in the wrong place?
Old Mar 20, 2022 | 01:08 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You will likely have better luck in the parts wanted section farther down the page or in specific boards dedicated for help with issues in different areas
This is a good spot for seat and steering wheel questions. Steering problems are more steering or suspension related I guess. Just look around , read a bit, and try the search feature. Good chance the questions and answers are already here. Good luck!
Old Mar 21, 2022 | 10:15 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Boards have been slowing down for years traffic wise, and see they see a good dropoff in the winter months as well as folks just aren't using their cars as much.
I'd recommend you call Hawks motorsports (they're one of the sponsors) and ask your questions about seat interchange and steering. They'd be able to sell you the used parts you're looking for as well.
For a bad tear, you may consider having the covers redone instead of replacing the seat itself (on either the one, or both fronts to ensure they match). Just a thought.
Old Mar 24, 2022 | 03:33 PM
erik69&85's Avatar
For the tough steering, I would check the steering box adjustment. If it gets overtightened, it will cause thought steering that you mentioned.
You loosen the lock nut on top of the box and then use a hex key to loosen the adjustment... Turn it back down until it starts to tighten, then back off about 1/8th of a turn. Hold the key steady and tighten the lock nut. This usually loosens up the box... If it still is right, the box may be failing... Or there is a bind in the linkage.
91z28BlkNY
Nov 18, 2010 10:18 PM
