Hawks rebuilt hatch motor unit
Old Apr 5, 2022 | 12:39 PM
CouleeCodger's Avatar
Car: 1991 Camaro RS
Engine: 6.0 LQ4
My rear hatch pull-down unit is being a real pain to repair. I have replaced cracked housings and screws, and yet it still does not work. I know that the unit gets power as when I got the car it was disconnected, and plugging it back in made the motor run nonstop. Now - nothing.
Not sure what is left to repair that is within my limited skillset, so I am considering getting a rebuilt one from Hawks:
1988-Early 1991 Camaro/Firebird Rebuilt Hatch Motor Pull-Down Unit - Hawks Third Generation (hawksmotorsports.com)
Anyone picked up one of these? I like the idea of a simple solution but the price tag is giving me pause.
Old Apr 5, 2022 | 01:28 PM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Re: Hawks rebuilt hatch motor unit
Following.
I rebuit mine, tested it, and then mounted it. Worked exactly once and died as you described.
Right now the trunk is manually latched and the worm gear needs to be tightened down once in a while to stay snug.
Old Apr 5, 2022 | 01:47 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Pricey, but these are getting to be pretty hard to find. I've never bought anything from Hawk's that wasn't new reproduction, but have never had a problem with anything I've gotten from them. They've been in business a long time and know thirdgens pretty well, so I would take a chance as long as you can afford the price.
Old Apr 5, 2022 | 02:11 PM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Sounds like an issue with the reverse switch on the motor assembly. They don't remake it unfortunately, but there are threads on here on how to rebuild it.
Old Apr 7, 2022 | 10:46 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
After rebuilding mine and having it barely work, I ended up getting a rebuilt from Hawks, glad I did because after I changed the rear seals a lot more motor torque is needed to get it to latch now.
Gouldjohnathan
Interior Parts Wanted
Feb 19, 2014 06:17 PM
pvt num 11
Apr 5, 2008 06:52 AM
camaro69_91RS
Dec 15, 2004 11:00 PM
da BEAST
Mar 3, 2002 02:07 PM
