Fuel Gauge ground wiring help
Old Nov 24, 2022 | 02:23 PM
Willie83's Avatar
Car: 92 Camaro rs convertible
Engine: 305 5.0
Transmission: Automatic
Hi have a 92 Camaro rs convertible,. My fuel gauge sits past full, I disconnected plug at rear seat hump connector and still stays past full, if I remove gauge put it on E and connect it back and turn key on goes back past full mark. I removed drivers rear seat cushion and I see where wiring comes to but I don't see the ground point where everyone is talking about, the three. Wires purple grey and black go into the driver's side rocker panel. Any help, any pics of the ground
Old Nov 24, 2022 | 06:08 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Fuel Gauge ground wiring help
Gauge goes to full when the circuit has high resistance, including open circuit.
I think the ground might be located under the driver's seat? I can't remember exactly. Just measure continuity between the connector at firewall and chassis ground, if there is virtually no resistance then you know you have a good ground.
Old Nov 26, 2022 | 08:57 AM
Willie83's Avatar
Engine: 305 5.0
Hey ty, I came to find out sender is bad, did the paperclip test too at connector and gauge when down to e, just gona change new pump and sender all one time, ty for your help.
Old Nov 26, 2022 | 09:09 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Thanks for the feedback, glad you got it sorted.
zwatkins15
Nov 20, 2020 06:55 PM
mr z28
Aug 9, 2014 03:44 PM
DennisCarithers
Jun 22, 2012 02:37 PM
walkthelin3
Feb 17, 2012 09:58 PM
firebird904
Feb 5, 2012 03:27 PM
