Hatch lock replacement
Old Apr 12, 2023 | 11:02 AM
sam816's Avatar
I finally found a couple 3rd gens at a mid way pull 30mins from me just for this hatch lock I pulled off this unknown year 25th anniversary rs not to fit on my 89 is there a way I can make it work? Or should I just bring it back and look at the other 3rd gens hatch?
One on the left is mine one on the right is new one
Old Apr 14, 2023 | 05:14 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Hatch lock replacement
They should work but not 100% sure
Old Apr 15, 2023 | 04:22 AM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
25th anniversary would be a 1992. If I'm correct, they are different from the 1986-1991 pull down motors in the way that they bolt on to the car.
Old Apr 17, 2023 | 08:37 PM
sam816's Avatar
thanks
Old May 17, 2023 | 10:15 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The tan colored plastic pull-down unit is from a 91.5-92. It will not fit your car. Get one from any 86-early 91 car instead.
Lon
HerpDerp1919
Apr 23, 2016 05:14 PM
shatteredgently
Jun 30, 2004 12:25 AM
