lighted manual shift pattern
Old Nov 20, 2023 | 10:56 PM
lewandom's Avatar
Car: 84 Z-28 Camaro, 2022 Chevy 2500
Engine: 383
A while ago I came across someone online who was selling the manual shifter panels with cupholders that also had a lit shift pattern....I cant remember the website for the life of me, I've been searching the internet for about an hour now, and I give up....does anyone know what website it was, I remember they had a whole bunch of different center console shift plates, auto and manual, with and without cupholders, and one of the options was a lighted shift pattern both 5 speed and 6 speed...I do remember you had to supply your own leather boot if that helps, I would defiantly appreciate any help.
Old Nov 21, 2023 | 12:30 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: lighted manual shift pattern
82-92 Camaro Custom Shifter Plate (Manual)|Unleaded Designs (unleaded-designs.com)
Old Nov 21, 2023 | 07:10 AM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
If you zoom in you can see the lit shift pattern. 7thDarkAngel is on this board and he also made the radio bezel in the picture.
Old Nov 21, 2023 | 09:08 AM
lewandom's Avatar
Engine: 383
thanks, I was searching for that site for like 3 hrs last night
Old Nov 21, 2023 | 03:10 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
I bought one and am happy with it. Here is review link.
https://www.thirdgen.org/forums/afte...ml#post6464062
Old Nov 22, 2023 | 10:30 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I've got his Double Din and the shift plate, both great parts.
Old Nov 22, 2023 | 01:49 PM
lewandom's Avatar
Engine: 383
I'm in the long process of upgrading/rebuilding my Camaro, I'm going to need a custom double Din bezel and it looks like he does them, I have a double din Kenwood head unit, and I'm putting a automatic digital HVAC unit from a late 90's Bonneville (I was trying to get a red display to match all the rest of the digital stuff I've put in, and in my experience later Pontiac stuff was red....but I assumed wrong as I found out once I wired it up...it seems anything that is red digital wont work for some reason or another) in, I've got the wiring and vacuum lines fig out, and when i test fit it, it mounted perfectly to the counsel where the original bracket mounted, but it sticks out more and the opening needs to be wider and taller than factory...so once I'm ready ill contact him with some measurements and see what he can do.
DeathMetalTony
Jan 3, 2010 09:32 PM
1983sc
Jul 18, 2006 12:44 PM
brian89transam
May 14, 2002 12:54 AM
IROC355
Mar 31, 2002 06:28 PM
Xenodrgn
Sep 2, 2001 04:26 AM
