Steering column swap
Old May 1, 2025 | 08:12 AM
Kdkane's Avatar
Does any body know if I can do a direct steering column swap and what it intels? I have a 90 Camaro Iroc and bought a 91 camaro Rs and was wondering if I can take the 91 steering column and put it in the 90? Thanks
Old May 1, 2025 | 01:32 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Steering column swap
As long as both cars are automatic or manual, should be a direct swap
Old May 1, 2025 | 02:55 PM
Kdkane's Avatar
Ok I didnt know with the whole Vats thing if that was going to be a issue
Old May 1, 2025 | 03:18 PM
Engine: 5.0
You will obviously have to transfer your old ignition lock cylinder unless you get the new key cut with the right resistor value
Old May 2, 2025 | 09:24 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Delay Wipers vs basic High/Low is also important...... Cruise Control too. That wiring runs inside the column so if your 90 has those options than you want the replacement column to also have those same options.
Bricks34
Aug 13, 2021 07:50 AM
Chris89FBForm
Apr 14, 2011 12:10 PM
