[For Sale] Parting Out 2002 Firebird Formula (no motor, heads only)
I bought this 2002 Firebird Formula a few months ago for the engine and assorted components for my 88 Trans Am GTA LSx swap. I have listed all the stuff I will not be needing.
Interior Note:**
The ebony interior has already been sold. The only parts left are the console(I have to repair the lid first), the front driver seats which is worn/torn in places, the front passenger leather ebony seat which needs a cleaning, rear ebony leather seats, the rear seat belts, trunk carpeting, and steering wheel/column.
Engine Note:**
The engine as a whole is NOT for sale. The main parts that I am KEEPING are the shortblock w/front and rear covers, windage tray, front accessories, PCM, fuel rail, engine mounts, coils/brackets, valve covers, ls6 intake manifold, coolant crossover pipe, starter, bolts/hardware and some other assorted things.
If you need a part that is not listed, AND I did not mention it in the comments about the interior and engine, ask me about it, I probably have it and just didn't list it.
Pictures are not of individual items for the most part but of the parts in general. Additional pictures can be provided upon request.
16" wheels, tires ok, 2 lose air over time 225
right fender BRACKETS (3) 75
left fender BRACKETS (3) 75
front bumper 200
front bumper support 100
rear bumper 25
rear bumper support 40
R fender 80
L fender 80
hood 125
hatch 40
r taillight 140
l taillight 140
taillight filler 40
r headlight, complete assembly 130
l headlight, complete assembly 130
passenger door 125
ttops pair 100
ttop conversion kit 110
r side mirror 40
l side mirror 40
splash guards 40
sail panel 250
wiper arms and linkage 40
wiper cowl 15
front side markers 10
rear side markers 10
wiper motor 25
fog lights pair 100
passenger 1/4 panel 250
driver 1/4 panel 150
turn/DRLs 100
hatch weatherstripping 10
air dam 20
taillight harness 75
Floor pans 80
front rails 150
rad support 200
rear seats 150
passenger seat 100
rear seat belts 50
center console 125
steering column 75
steering wheel 50
radio 20
gauge cluster 40
climate controls 25
rear view mirror 10
ebrake 15
shifter 20
pedals 10
driver door glass 15
window motor 10
sill plates 10
sail panel speakers 50
monsoon amp 10
transmission(40k on trans with paperwork) 600
rear axle(3 ch) no brakes/suspension 200
LS1 rear brakes 100
241 heads 100
exhaust manifolds 80
stock y pipe 50
catalytic convertor driver (non OEM) 25
catalytic convertor pass (non OEM) 25
k member bare 50
ls1 engine stands 30
stock rear LCAs 20
stock panhard 15
stock panhard brace 10
brake master 50
brake booster 40
abs block (3 ch) 80
rear sway bar w/endlinks 50
front sway bar w/endlinks 50
steering shaft 40
steering rack 120
front brake hard lines 40
rear brake hard line 50
transmission lines 80
shifter cable 40
LS1 rockers w/stands 85
LS1 28# injectors 120
airbox lower 50
air lid w/baffle 30
trans crossmember auto 30
MAF 80
LS1 front spindles 50
ac / heater box 50
LS1 oil pan 200
Interior Note:**
Engine Note:**
front bumper 200
rear bumper 25
R fender 80
L fender 80
hood 125
hatch 40
r taillight 140
l taillight 140
taillight filler 40
passenger door 125
ttops pair 100
r side mirror 40
l side mirror 40
splash guards 40
sail panel 250
wiper cowl 15
wiper motor 25
fog lights pair 100
turn/DRLs 100
air dam 20
Floor pans 80
front rails 150
rad support 200
rear seats 150
passenger seat 100
rear seat belts 50
center console 125
steering column 75
steering wheel 50
radio 20
gauge cluster 40
climate controls 25
rear view mirror 10
ebrake 15
shifter 20
pedals 10
window motor 10
sill plates 10
monsoon amp 10
LS1 rear brakes 100
241 heads 100
stock y pipe 50
k member bare 50
stock rear LCAs 20
stock panhard 15
brake master 50
brake booster 40
abs block (3 ch) 80
steering shaft 40
steering rack 120
shifter cable 40
airbox lower 50
air lid w/baffle 30
MAF 80
ac / heater box 50
LS1 oil pan 200
Car: 89 GTA & 92 T/A covertible
Engine: 408LS-SC, 355 TPI
Transmission: 4L80e, 700r4
Axle/Gears: 12 bolt, 9 bolt
Re: Parting Out 2002 Firebird Formula (no motor, heads only)
Non traction control Cruise control servo/cable?
As or right now, I'm keeping the cables and parts for my own swap, not sure what I'm exactly going to need or if I will be using the ls1 cruise setup or not.
The '98 z28 I parted had traction so that wouldn't work for you I assume.
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
