[For Sale] LSX fuel rails, regulator and lines for ls swap
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Im selling a partial fuel system for an LS swap. This is for an LS1/LS6 intake. This is a direct fit for an original TPI car. The fuel rails and regulator are Professional products brand. The lines and fittings are Summit and earls brand. The regulator mounts to the shock tower and the feed to the regulator connects directly to the 3/8 feed line with the correct 16mm fitting. The return is connected just behind the motor on the frame rail to the factory 5/16" return line with a compression to -6 an fitting, a new one is included. This was a great working system and worked great on my car into the 700 hp range on pump gas and still had a lot more in it. I only removed it since im going with e85 and wanted to start fresh with everything. The regulator is a 1:1 boost referenced. There also is a gauge adapter on the end of the p/s rail, can be plugged if not used. I would like $200 with free shipping anywhere in the US. Paypal accepted. Thanks
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Re: LSX fuel rails, regulator and lines for ls swap
I may be interested in this. Need to see what I all need first.
luvofjah
Jan 22, 2016 03:26 PM
carid
Sponsored Vendors
Dec 7, 2015 07:57 AM
