LSX and LTX Parts Looking to buy or sell LSX or LTX parts? Post it here.
[For Sale] SOLD [IN] - 5.3 LM7 4 Spd T56 Swap Setup - 1600 for All
Old Sep 24, 2017 | 01:35 PM
lonewolf583's Avatar
Car: 10 Camaro SS
Engine: Stock LS3
Transmission: TR6060
Axle/Gears: Factory LSD 3.45
SOLD.
Hey all, bit of a firesale going on, here. Wanted to offer this up here to those who would appreciate it.
I'm selling essentially a very close to turn-key and runnable LS swap setup. The stand goes with the setup. It is missing some basic nuts and bolts and plug wires.
I WILL NOT SHIP. Asking $1600 OBO for everything. Local pickup only from Seymour, IN.
This is a 2001 LM7 5.3 with fresh bearings, rings, TR220 cam @ 114 LSA, and LS6 yellow valve springs. It ran well when I pulled it. Front steam tube needs to be replaced. Can go to any pull a part and get it for about $10-15.
The engine had spent life in an autocross race car and did not spend much time on the track.
The transmission is a 1996 F-body LT1 unit converted to an LS1 input. 5th and 6th were worn excessively and removed due to this being an autocross only car. This is effectively a 4 speed T56.
If someone wanted to restore it to a 6 speed, all they would need to do is have their transmission rebuilt with those gears and forks back in it. I do not have those parts. Pretty easy to do. Worst case this becomes a cheap core for you if you don't want to mess with it.
Included with the entire setup is a LUK Stage 1 clutch and flywheel setup, the B&M Pro Ripper shifter and slave cylinder, Spohn transmission swap crossmember, Hawks LSX swap headers, Edelbrock carbureted performer RPM manifold, Holley 750 vac secondary carb, MSD 6010LS ignition system and factory coils with harness to run the box. 2001 silverado water pump, hawks billet engine mounts, truck alternator, accessory drive brackets, and an 89 GM truck power steering pump. Accessories fit under the hood with room to spare.
PM or post below if you have questions or want different pictures.
Old Sep 24, 2017 | 11:09 PM
Holmes's Avatar
Car: 1991 Camaro Rs/Z28 clone
Engine: 5.3LSX
Axle/Gears: DTS 12 Bolt 4.10
Re: [IN] - 5.3 LM7 4 Spd T56 Swap Setup - 1600 for All
Interested, and somewhat local, I live in northern indiana
Old Sep 25, 2017 | 07:14 AM
Car: 10 Camaro SS
Engine: Stock LS3
Sending PM.
Old Sep 27, 2017 | 07:23 AM
Car: 10 Camaro SS
Engine: Stock LS3
Pending sale, thanks for the interest.
Old Sep 30, 2017 | 08:42 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
If this falls through I'll be next in line!
Old Oct 7, 2017 | 09:48 PM
Holmes's Avatar
Engine: 5.3LSX
Picked up today, thanks again!
Old Oct 9, 2017 | 07:02 AM
Car: 10 Camaro SS
Engine: Stock LS3
As he said, she's sold!
