[For Sale] LS T56 PACKAGE BORGWARNER T5 MORE T56's 12BOLT K-MEMBER MORE MORE MORE
Car: 86 iroc
Engine: Iron 408 LS3 combo
Transmission: Ram10 T56
Axle/Gears: 3.73 10 bolt :)
Hello first off sorry if this add is confusing, i have 2 LS R56's and really need some $$$.. I am located in Buffalo NY but will be more than happy to ship or possibly even meet part way.
I do not like pay pal... I have been burned 1 too many times as they have NO protection for there sellers.. buyers are a diffrent story.. so I prefer cash, FaceBook is a great way to send money or if i have to I will use PayPal but you cover their fee's... I don't come on here all that much but you can PM me for sure, the best way to contact me is by text message, my cell # is (716)428-1674, my name is Adam...shoot me a text with your name and what you are inquiring about and I will get back to you A.S.A.P. after seeing your text. If you post on this thread I more than likely won't notice for a while. Also calls are fine, I work wired hours but no time is too late, if I'm asleep you won't wake me up lol..
Ok so the first T56 I have avalible is a 1999 LS T56 Transmission pulled from my friends 110,xxx mile street/strip car last season and gone through and Freshend up, just the necessities and billet keys...
300 miles at best since it was Freshend
I also have some other parts to go along with it... if rather sell them in a whole deal as I need the money, and if I can't make up some good cash here is rather keep the trans for my Iroc..
---So what I'm offering is a package
*Fresh LS T56 Transmission
*OEM LS Bellhousing
*GM Slave Assembly (Used)
*Centerforce Performance ThrowOut Bearing (New)
*GM Performance Pilot Bearing (New)
*ARP 12pt. Bellhousing Bolts (New)
*ARP 6pt. Flywheel Bolts (New)
*Energy Suspension Poly Trans Mount (New)
*Energy Suspension Poly Torque Arm Bushing (New)
*OEM GM F-Body 99 Camaro Shifter Assembly
*OEM Shifter Boot...****, ect...
---CHOICE OF THE FOLLOWING
*GM LS7 Clutch and Flywheel Assembly (New)
*GM Flywheel and SPEC Single Clutch Assembly (New)
***Both Include ARP Pressure Plate Hardware (New)
Asking $2,700 OBO can mabey work in some more parts to achieve the price... have tons more LSX/SBC/...G-Body but mostly F-Body OEM & Performance parts Engines/Trans/Rears/Suspension/Steering/Chassis/Electrical/Exhaust/Wheels&Tires/Brakes/Fuel Systems/Body/Interior/Glass/Nitrous Systems/Go Fast Goodies...
Offers are certainty welcomes but please no low *****... I need the cash but some trades like Name Brand tools and 3bay box, cool projects... no late model cars/bikes/sleds/Atv's/ lawnmowers or toasters! Lol
---Also have the following if interested
*UMI Tubular K-Member with LS Motor Mount Plates, Stock Spring Brackets for use with Standard Springs & Steering Set ups..*-*-*-I WILL NOT sell this by itself... if you are purchasing a trans or rear end I will consider it..
*Wilwood Aluminum Adj. Master (New)-3an braided line & fittings
$75
*Tilton Aluminum Adj. Master (New)-3an braided line & fittings **For Use with a Remote Relocated Reservoir**
$100
Wilwood Aluminum Clutch Or Brake Pedal Assembly w/Braket that can mount too the floor with pedal pointing up.... OR mount up on the firewall/under dash with the pedal hanging...(Made to work with either of the above mentioned masters)
$75
*4th Gen F-Body (93-02) Manual Pedal Assembly (Clutch and Brake Pedal with all electronics(NO GAS PEDAL)
$75
*3rd Gen F-Body Manual Pedal Assembly (Clutch Pedal Only)
$50
*3rd Gen F-Body Manual Transmissin Tunnel (Rust Free... Cut for use as template for myself)
$50
*3rd Gen F-Body Manual Upper Console Shifter Plate Surround w/Boot **NO PWR Windows** No Cracks, Good Ashtray....
$125
*1982-2002 F-Body Driveshaft ... Fits T5/T56/700R4/4L60E with 10Bolt.. Aluminum Driveshaft from 98-02 SS Car, Low Mileage good U-Joints...
$100
*New Auburn Style 7.5" Posi Unit (Series 3)(28-Spline)
$200
*New Eaton Posi Unit 7.5" (Series 3 26-Spline)
$375
*Used SS 2002 GM Torsion Style Posi Unit 7.5" 135,xxx miles (Series 3 28-Spline)
$150
*NEW 7.5" GM 3.73 Gear Set
$75
*NEW 7.5" 3.42 Gear Set (Unkown Brand..believe GM)
*USED 7.5" 4.10, 3.23, 3.42 & 4.10 Gear Sets **To be sold with a posi unit)
*ARP 7.5" GM 10Bolt Carrier Bearing Cap STUD KIT & Perfect Launch Aluminum Girdle Cover w/Lash Caps
$250
*Camaro Doors, Pass/Driver in decent condition (pic up only)
$80ea
*Camaro Fenders Pass/Driver in OK condition
$75ea
*GM N.O.S. NEW Camaro Fenders PAIR
$350
*IROC-Z28 Front Bumper Ground Effect Excellent Condition
$200
---WORLD CLASS BORG WARNER T-5 Package
*80,xxx Mile good working order BorgWarner WorldClass T5
*GM Crossmember
*GM Torque Arm Mount Assembly
*SBC Bellhousing
*ARP Bellhousing Bolts
*ARP Flywheel Bolts
*Budget Performance Clutch and GM Flywheel
*3rd Gen Manual Pedal Assembly
*4th Gen Aluminium Driveshaft
*Camaro Shifter Assembly
*Center Console Shifter Plate Surround & Boot (NO CRACKS)
*Pilot Bushing
*Rust free manual transmission tunel
*New Energy Suspension Poly Trans Mount and Torque Arm Bushing
ALL NEEDED HARDWARE AND EXTRAS TO BOLT IN
$1,250
SECOND LS T56...130,xxx miles
-Needs Input Shaft ***NOT INCLUDED***
-Needs Minor Repairs, Transmission is coming out of 4th gear..
-Includes another OEM LS Bellhousing
$1,350 OBO... w/Bell..
$1,200 w/o Bell
If you want to do a package deal like the first I mentioned except want to buy this transmission instead the asking price is $2,000
---Clutch & Flywheel Assembly's on they're own
*LS7 GM Performance Clutch & Flywheel Assembly (New)
$450
*GM Flywheel & SPEC Single Disc Clutch Assembly (New)
$525
*-*-*-*-*STRANGE ENGINEERING HEAVY DUTY OLD 12 BOLT FOR FBODY..... WITH DRIVESHAFT AND TORQUE ARM!*-*-*-*-*
---Strange Engineering **82-92 Axle Length** Custom Built Pro 12Bolt.
*Upgraded Housing with larger Axle Tubes, Welded Tubes...
*"BIG FORD" Bearing End Upgrade
*H.D. Strange Upgraded 33-Spline Chromoly Axle Shafts
*H.D. Strange Upgraded Chromoly 1350 Pinion Yoke
*H.D. Strange 33-Spline Steel Spool
*Richmond Gear 4.56 Upgraded "RACE" Gear Set
*ARP Upgraded 5/8" Wheel Studs X 2"
*11" GM Drum Brake Option (Can Convert too Discs..)
*ARP Carrier Bearing Cap Studs
*Fully Welded LCA Relocation Brackets for 1-3" Axle Drop
---Strange Engineering H.D. 3" Cromoly Driveshaft
*Includes Upgraded Strange 1350 Chromoly Transmission Yoke
*New 1350 U-Joints Installed
***Made for this Axle and Standard Posistion Fbody Transmission... was a T56 Car..***
---Fully Adjustable Tubular Cromoly Torque Arm Assembly
*EXTREMLY HEAVY DUTY REAR BRACKET..too mount it too the 12Bolt
*Stock Style Bushing Used up front... this means with the addition of a BMR/UMI or similar Torque arm relocation Transmission Crossmember you will have the ability to actually adjust ANTI-SQUAT... UNLIKE the Crossmember/Torque Arm Combos that don't use the GM style front bushings, these while they claim to be "Adjustable" they actually only allow for pinion angle adjustments....
---Competiton Engineering 3-Way Adjustable Rear Shock Absorber's...(New)
***THIS REAR END HOUSING Has the threads for a reluctor wheel sensor too pic up TCS or ABS Readings on 3-way and 4-way 4th gens...(would need to press on reluctors)***
---Strange 12 Bolt...Strange Moly D/S w/1350's...Moly Tubular Torque Arm and Comp 3-Way Rear Shocks
$2,250 FIRM.
****Will ship at buyers expense(usually $350 too crate and ship to your door) Lower 48...***
Thank you for your time and patience,
Adam Bainbridge.
@(716)428-1674...Buffalo..NY..
*OEM LS Bellhousing
$75
$100
$75
$75
$50
$50
$125
$100
$200
$375
$150
$75
$250
$80ea
$75ea
$350
$200
*GM Crossmember
*SBC Bellhousing
*ARP Flywheel Bolts
*Pilot Bushing
$1,250
$1,200 w/o Bell
$450
$525
$2,250 FIRM.
Adam Bainbridge.
Car: 1988 Irocz
Engine: 350 sbc
Axle/Gears: 3.42s i think??? never checked
Re: LS T56 PACKAGE BORGWARNER T5 MORE T56's 12BOLT K-MEMBER MORE MORE MORE
How much for the tubular k member and will yoi ship it?
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
