a real general description is "engine coolant temp high-fuel disabled"
i have no clue? the car will run and idle fine, but wont rev at all.
could it be just a shorted wire or a bad sensor. the scan tool just says 280* all the time, and the guage is pegged, even when you first start the engine.
anybody have any ideas where to start? to me it seams like a shorted sensor
High temperature indicates a short to ground. Either the sensor is bad or the wire is pinched/rubbed through somewhere. You mentioned that the ECM not only reads high, but the sensor is pegged. How do you have them wired up????? Are you using the '98s 3-wire sensor????
i believe its a two wire sensor. its stock for the 99 f-body
i didnt really change any wires around, just plugged in and went since im using a complete 4th gen harness, gauges, etc....
i will be looking at it tomorrow to figure it out, maybe its as simple as a bad sensor i hope
Unplug the coolant sensor and see if the computer reads -40°
If its does read that, then the wiring and computer are probably working and the sensor may be bad. If it still reads over 280, then you probably have a wiring or computer issue.
xtremeirocz
close
- Join DateMay 2003
- LocationHouston-katy
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1986 Irocz- Houstons Fastest Street
- Engine408 LS1 w/ 2 stage
- TransmissionTurbo 350
- Axle/Gears3:73,3850 lbs , best of 9.92 @ 138
- Liked:0 Times in 0 Posts
i had a software issue in the ecm that gave me that code. after fighting it for a few days went and got a new ecm and problem solved. hope it isnt whats wrong here
finally got to spend a few minutes on it tonight, found the wire shorted to the dash frame
its all good now though
thanks
thanks
