Lt1 Swap Underway
Old Jun 23, 2005 | 09:26 AM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
Lt1 Swap Underway
I just looked at a LT1 with full harness and 4l60e. Picking it up sunday. It is set up for 95-97 ecms(the ecm comes with it to). I have a 85 transam. I have searched and really am confussed about the under dash wiring. Are the wire harness connectors the same and just need repinned? Also can I use my shifter? What guages do I have to use? I do not really want a fourth gen dash but I am thinking of aftermarket gauges that would work with the LT1. I have just began collecting things and need to know more specifically to the swap. Any and all help is greatly appreciated, but try to stay away from bashing others ideas I like to read tech not arguments.
Old Jun 23, 2005 | 09:47 AM
305TA85's Avatar
I am also going to rebuild the engine before it goes back in. Stock bottom end (new bearings, rings, and seals). I want to convert to LT4 intake with performance LT4 heads (need advice on wich heads to get). I am probably going to buy the LT4 hot cam kit for it. Then tune it all in.
Old Jun 23, 2005 | 02:57 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Bang for buck, I have heard the hotcam kit doesn't help that much over stock. As for the underdash wiring, everything for the gauges will be tied into the bulkhead connector and the injectors will tie into the two connectors under the passenger side of the dash.
Old Jun 23, 2005 | 05:50 PM
kevinc's Avatar
Car: 1982 Z28
What clearance are your planning for on your main and rod bearings?
Old Jun 24, 2005 | 07:00 AM
305TA85's Avatar
Do not know yet. I haven't checked out any of the specs. I am up for suggestion though. I think its .002-.003 thousandths, not sure.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
