Heater Delete
Old Jun 25, 2005 | 02:45 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Heater Delete
What did some of you guys that deleted your heat on your LS1 do to block off the Heaters In and Out on the water pump?
This is what I ended up doing until I find a better looking and more effective way of doing it. Those are old lug nuts in there.
Old Jun 25, 2005 | 11:38 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
i did the same thing.. but used a hose to go from one to the other :|
same difference
Old Jun 26, 2005 | 08:04 AM
kevinc's Avatar
Car: 1982 Z28
Some of the guys who capped the input/output fittings reported problems w/ the engine overheating.
The conclusion they reached was that flow to the thermostat is affected when you cap the fittings...best to connect them in a short loop.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
