ecm wire for air fuel?
trying to hook my novelty autometer air fuel guage with the ls1 ecm and i don't have a manual handy. anyone know what wire controls this. it was purple with the tpi 730 but i have no idea now??
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its still the purple wire..... on the drivers side front O2 sensor....
you can do a search on LS1tech.com to double check..
Car: 91 Camaro Vert
well, last time i put one on, i did it there because it was right there.
the other end of the wire works just as well.
what year PCM\harness is it?
if its a [b]1999 - 2002[b] this one applies:
http://66.83.134.202/travis/LS1swap/...M%20Pinout.htm
if its a 98, that is NOT correct.
Car: 91 Camaro Vert
from the pinouts i have:
BLUE pcm connector:
BLUE pcm connector:
Code:
pin wire name desc 65 PPL HO2S SIGNAL HIGH BANK 2SENSOR2 Passenger side rear sensor 66 PPL HO2S SIGNAL HIGH BANK 2 SENSOR 1 Passenger side front sensor 68 PPL/WHT HO2S SIGNAL HIGH BANK1 SENSOR 2 Drivers side rear sensor 69 PPL/WHT HO2S SIGNAL HIGH BANK 1 SENSOR 1 Drivers side front sensor
thank you very much, anyone have troubles with an air/fuel guage causing ecm problems? threw one on a 00 a while back and it gave a few problems. i'm thinking about dedicating a o2 for it in the exhaust so i don't have any issues.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
