throttlebody coolant bypass/vacuum q/a
Old Aug 28, 2005 | 05:20 PM
mrfbody's Avatar
just wondering what every1 uses to plug the 2 holes in the back of the cylinder heads.
i am guessing the original bolts are way too long. should i use like a npt plug or just match up a different bolt and use some sealent on it?
also the seems to be a 3/8 vac hose on the tb below the pcv hose and above the coolant hose on the passenger side. is it for the ccp perhaps? or maybe the other end of the pcv system?
Old Aug 28, 2005 | 09:29 PM
TexasLT1's Avatar
Car: '92 RS
do NOT plug those holes, you need them and the steam line that comes forward along the passenger side cylinder head. the TB bypass is just that, bypassing the ports on the TB and connecting the steam line directly to the coolant lines or the radiator depending on how you have it hooked up
Old Aug 28, 2005 | 09:34 PM
mrfbody's Avatar
thanx, i just got through talking to some1 about that on im.
Old Aug 29, 2005 | 09:10 AM
Firebat's Avatar
pic for 95-97 LT1 TB Bypass
http://shbox.com/1/tb_bypass.jpg
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
